HyperX QuadCast S Pop Filter Replacement
    1. HyperX QuadCast S Pop Filter Replacement, Tap-To-Mute Sensor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HyperX QuadCast S Pop Filter Replacement, Tap-To-Mute Sensor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HyperX QuadCast S Pop Filter Replacement, Tap-To-Mute Sensor: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Set the microphone on a flat surface.
      • Pull each of the support bands upwards and off of the notches to release the microphone from its base.
      • There are four support bands in total, but it does not matter which band you choose to take off first.
    2. HyperX QuadCast S Pop Filter Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HyperX QuadCast S Pop Filter Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HyperX QuadCast S Pop Filter Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Grab ahold of the tap-to-mute Sensor and pull it upwards in a clockwise motion.
      • Be careful not to damage the cable as you remove the top.
      • Once the tap-to-mute sensor detaches from the microphone, you will hear a small "pop."
    3. HyperX QuadCast S Pop Filter Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HyperX QuadCast S Pop Filter Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HyperX QuadCast S Pop Filter Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently unplug the cable, and remove the tap to the Tap-To-Mute sensor from the microphone.
      • The square indicates the location of the cable. This is cable is very small and will require a bit of force to be unplugged.
    1. HyperX QuadCast S Pop Filter Replacement, Pop Filter: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the Tap-To-Mute sensor has been removed, you will now have access to the pop filter.
      • The pop filter is just the grey foam surrounding the inside of the microphone.
    2. HyperX QuadCast S Pop Filter Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The pop filter will be in a fixed position being glued to the wire. Remove glue residue before continuing to remove the pop filter.
      • When you replace the pop filter, remember that you will need to glue it back into place as before.
    3. HyperX QuadCast S Pop Filter Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HyperX QuadCast S Pop Filter Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Reach into the microphone and remove the pop filter.
Nathan Arruda
crwdns2935283:010/25/22crwdne2935283:0
765 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-1, Sinclaire Fall 2022 crwdns2935289:0UMass Dartmouth, Team 4-1, Sinclaire Fall 2022crwdne2935289:0
UMASSD-SINCLAIRE-F22S4G1
"Grab ahold of the tap-to-mute Sensor and pull it upwards in a clockwise motion."
This part is keyed. It literally cannot be pulled in any rotational motion...
Kyle Villalovos - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Is there a place where you recomend i can get a replacement peice of foam for the pop filter. I cant find one anywhere online.
Liam Henesy - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 46
crwdns2936753:030crwdne2936753:0 142
crwdns2942667:0crwdne2942667:0 4,729
