crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your HP ProBook 640 G5 fails to connect to Wi-Fi networks, cannot detect available wireless networks, or drops connection unexpectedly, follow this page for possible solutions.
Failing WLAN Module
If all software, drivers, and settings are correct and the laptop still cannot connect, the wireless adapter hardware itself may be failing or disconnected.
Check the wireless adapter in Device Manager → Network adapters; if it shows errors or fails to start, this may indicate a fault.
Test with an external USB Wi-Fi adapter. If this connects successfully, the internal WLAN module likely needs replacement.
Inspect antenna cables and connectors if you’re comfortable opening the laptop.
Follow the WLAN replacement guide to access and replace the internal Wi-Fi module.
HP ProBook 640 G5 WLAN Module Replacement
Eric Olivarez
crwdns2935283:002/23/26crwdne2935283:0
449 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 1-2, Anderson Spring 2026 crwdns2935289:0Austin Community College, Team 1-2, Anderson Spring 2026crwdne2935289:0
AUSTINCC-ANDERSON-S26S1G2
crwdns2935297:069crwdne2935297:0
crwdns2942667:0crwdne2942667:0 102
