crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Laptop is Overheating
When in use, the computer begins to get hot and suddenly shuts off without a warning.
Debris in Vents or Fan
If the laptop overheats during use, there may be debris blocking the fan vent. Clear the fan vent (located on side) using a dry cloth, a Q-tip, or compressed air. If there is still visible dust, hair or other debris on the inside of the fan vent, the laptop case may need to be opened to fully clear the area. Refer to the motherboard replacement guide for directions on opening the case and locating the fan.
Fan Needs to be Replaced
After all the debris has been cleared, if the overheating issue persists, the fan may need to be replaced. This is due to melting of the fan. Melting is caused by overuse of fan, damage to fan, or the fan being faulty.
Keys Not Functioning
The keys on your device keyboard are not functioning or the keys are jammed.
Keys are Immobilized
If you have sticky keys, the first thing you should do is determine whether the keys might be jammed. Check if some beverage was spilled on the keyboard. If so, you will need to take the keys out and clean them individually. To take the keys off individually, you can use a guitar pick, a flexible ruler, or anything that you can wedge into the key and pull it out. If nothing was spilled on the keys another solution may be a can of compressed air and apply to slits by the keys.
Headphones are not Working
The headphones are not working when you plug them into the headphone jack.
Driver not Working
Test the audio on the laptop's speakers, to see if the sound is distorted when listening through the speakers (if the sound is distorted, you might want to check out how to replace the speakers). If the laptop's speakers work, test it using headphones. If the audio is distorted only when listening through the headphone jack, the audio jack or headphones may be faulty.
Physical damage to headphone jack
Verify that the headphone audio plug is inserted all the way. If it's still not capable, the audio driver may be corrupt, grubby, or can have a small item jammed. If the headphones are suitable, verify that the default sound device is set correctly. For most users, the default device is speakers. Change the default device to Headphones. Click on the Volume icon and select the level tab, make sure the volume is on and not on mute. It can also be a tear or mishap with the jack. A common problem with the headphones being inserted and removed roughly, is it causing damage to the headphone jack.
Encountering a Black Screen
The laptop displays a black screen but the power button is on.
Faulty Screen
If your laptop shows that the power is on, but the screen is completely black, try plugging it in to an external monitor. If the laptop displays on the external monitor and functions, you may need to replace the LCD on the laptop. With the laptop overheating, this may also impact the screen display. If the laptop still displays a black screen, you may need to replace the screen.
Misael Calleja
crwdns2935283:009/15/16crwdne2935283:0
192 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
CSU Fullerton, Team 1-2, Bruce Fall 2016 crwdns2935289:0CSU Fullerton, Team 1-2, Bruce Fall 2016crwdne2935289:0
CSUF-BRUCE-F16S1G2
crwdns2935297:048crwdne2935297:0
My HP says push control alt delete to get it going I do that and it doesn't work what do I need to do
bret mccollum - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 1,117
