crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Will Not Print
If your device is refusing to print jobs in queue, use the following troubleshooting solutions.
No Connection to Printer
Make sure your device is either connected to your network or connected by USB.
Drivers are out of Date
It is always good practice to keep drivers updated. Download the most recent drivers here, select the appropriate operating system and version for your computer and download the driver installer. Run the executable and follow the onscreen instructions. Be sure to restart your computer after installing fresh drivers.
Power Cord Connected Insecurely
Make sure the power cord is securely plugged into both the outlet and the printer. If it is secure and the problem still persists, follow this guide to replace the power supply in your device.
Display is Unresponsive
If the display will not respond to input or appears frozen, check the following problems.
Device Requires Reset
Press the power button to turn off the printer. Wait 60 seconds and power the device back on.
Power Cord Connected Unsecurely
Making Loud Noises
If your printer sounds louder than normal or is making a clicking or crunching sound, check the following.
Printer is Jammed
See if any pieces of paper are stuck in the feed tray. If there is paper stuck in the tray, turn the printer off and remove the jam.
Broken Internal Pieces
If there are any broken or rattling parts, see this guide on replacing the paper tray and check for any loose pieces in the printer.
Will Not Turn On
If your printer will not power on, or is completely unresponsive check the following potential problems.
Printer is Not Plugged In
Plug the printer into a standard wall outlet, then press the power button on the front of the printer.
Outlet is Bad
The outlet that the printer is plugged into is not working. Plug the printer into a different outlet. If the printer is plugged into a power strip, try plugging directly into a grounded wall socket. Press the power button on the front of the printer once you have ensured an electrical connection.
Power Cord is Bad
Check the power cord for sharp bends and exposed wire. Replace the power cord if any signs of damage are present.
Power Supply is Broken
Replace the power supply on the printer. Follow this guide to see how to replace the power supply.
Print Quality is Poor
If print jobs are not coming out as expected, is blurry, or contains vertical stripes, check the following symptoms for potential problems.
Printer is Out of Ink
Replace the ink cartridges for your printer. To see this done, visit this guide.
Ink cartridges are inncorrect
Replace the ink cartridges with hp approved ink cartridges. To see how to replace the ink cartridges, visit this guide.
Print head is dirty
Go into the menu on the printer and select clean print head.
Tyler Allen
crwdns2935283:001/24/18crwdne2935283:0
513 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S18-G3, Livingston Winter 2018 crwdns2935289:0Cal Poly, Team S18-G3, Livingston Winter 2018crwdne2935289:0
CPSU-LIVINGSTON-W18S18G3
crwdns2935297:084crwdne2935297:0
crwdns2944067:040crwdne2944067:0
When printing product top margin to large
lawrence cotgrave - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My printer works fine but will not copy now great I'm getting a message of something broken I believe it was jammed at one time. How do I fix this?
sherry - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My 4630 printer is making a loud noise as he paper is advanced in the printing process?
Why is there never any advice on the necessity for LUBRICATION? Ink cartridge slide bar? Other places for lubrication?
Thanks
CP
wpilgrim71 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Recently replaced printer cartridges with #61, tricolor and black and white. Now it prints only black, and that is a bit smeary. The screen says “Printing in single cartridge mode.”
Janet Wong - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
When printing, clip art backgrounds are printed black when they should be white. It never used to do that. I recently changed to getting my ink cartridges by mail from HP.
Debbie
Debbie Duckworth - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 90
crwdns2959996:0crwdne2959996:0 21,283
