Laptop Will Not Turn On
The Laptop will not turn on and the screen is blank.
Laptop Is Unplugged
Make sure that the power adapter (charger) the laptop came with is connected to not only the laptop but into a working outlet as well.
Laptop Is Plugged In
There is a light located on the side of the laptop that lights up when the adapter is correctly plugged in. If adapter is plugged in and light does not turn on, consider getting new adapter.
Faulty Battery
If your laptop wont stay on when unplugged then you may need to replace your battery. See our replacement guide here.
Keyboard or Keys Not Responding or Sticky
The entire keyboard or specific keys are not responding or are sticky.
Entire Keyboard Not Responding
If your entire keyboard is non-responsive then you may need to first restart your laptop. If unsuccessful you will then need to replace it. See our replacement guide here.
Keys Are Sticky
If specific keys are sticky you can try to wipe around the key using a Que-tip dabbed in isopropyl alcohol. If unsuccessful you may have to replace these keys. See our replacement guide here.
Screen Not Displaying
The laptop is on but the screen is black or not displaying properly.
Screen Came on But Shutoff
Your laptop most likely died, see our above solution for the laptop being unplugged.
Screen Does Not Come On
If the power button on the laptop located towards the top left of the keyboard is lit, then that means the screen could possibly be damaged. See our repair guide here.
Laptop Overheating
The laptop feels warm and is running slow.
To Many Programs Running
Sometimes you can work a laptop to hard by running to many programs at once. You should try restarting your computer.
Laptop Running Slow
The laptop is taking long times to do simple tasks.
You may have to restart your computer since you have to many programs running. Also having your laptop on for long periods of time can cause this to occur as well.
System Restore
You may have to do a system restore, which will completely wipe your entire computer and will help it run faster. *WARNING* (Doing this will get rid of everything on your computer be sure to back up important documents and files). You can this by searching for system restore and selecting it.
Anthony Ciotti
crwdns2935283:003/10/16crwdne2935283:0
517 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
UMass Dartmouth, Team 4-5, Catania Spring 2016 crwdns2935289:0UMass Dartmouth, Team 4-5, Catania Spring 2016crwdne2935289:0
UMASSD-CATANIA-S16S4G5
crwdns2944067:05crwdne2944067:0
My Hp 15 f272wm has the following issues :
Files and folders on screen and in the disk blink frequently, cursor blinks and one is unable to access the files or even Highlight them.
Any solution to the above problems?
Benson Waithaka - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I'm having an issue where my laptop won't come on at all. Tested the voltage on charger, it's fine but no light when plugged in. Only light that comes on is a power light (front right side) and it's white. I've tried all solutions Google offers and nothing
Autumn Gayhart - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have certain keys that are not working or responding at all. I've cleaned them. But they still are not working. Help!!!
sjcarroll109 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 2,607
