crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Laptop Dies When Unplugged
The laptop will only turn on when plugged in to the power cord.
Low Battery or Damaged Battery
First, ensure that the battery is properly installed in the laptop by following the battery replacement guide. Once the battery is properly installed, try charging the laptop with the appropriate charger for at least fifteen minutes. Then, unplug it and try to turn it on. If the laptop still will not turn on, a damaged battery may be the case. You can find replacement battery parts for a Gateway T-6842 at the following link.
Damaged Power Connection
If the laptop’s battery does not charge when connected to the power cord and the light on the power connection doesn’t illuminate when plugged into the power cord, the power connection may not be functioning properly.
Computer Will Not Boot
The computer crashes when loading the Operating System or shows an error message.
RAM Malfunction
Symptoms indicating issues with the RAM include errors on start up, a stop error (The Blue Screen of Death), sluggish performance, and crashing when running memory intensive programs. When these symptoms arise, the RAM card may have come loose or become faulty. See RAM replacement to ensure the RAM card is correctly installed or to replace malfunctioning RAM.
Hard Drive Error
There could be an error on the hard drive due to an unexpected shutdown. To resolve this issue, boot your laptop from disk. This process is done by inserting disks that should have been included with your laptop from purchase. If booting from disk does not allow the computer to boot correctly, the hard drive may need to be replaced.
No Display
The monitor does not display anything when it is turned on.
Physically Damaged Display
If the display is cracked, has dead pixels, or has permanent isolated color distortions the entire screen needs to be replaced. Follow these display replacement steps to replace the screen.
Jammed or Missing Keys
The keyboard keys do not respond when depressed or are missing.
Keys Not Reacting
If there is no response from pressing any of the keys, then the keyboard may be broken or have become disconnected. The keyboard replacement guide is here: keyboard replacement guide.
Keys Cannot Be Pressed Down
If the keys cannot be pushed down, there is a possibility that something is underneath the actual key preventing it from being pushed. The problem key needs to be taken off from the keyboard. The underlying area needs to be wiped of any debris that may be causing this malfunction.
Keyboard Has Missing Keys
If the keyboard is missing keys, then replacement may necessary to correct the issue. Information about replacement keyboard parts can be found under Additional Information on the Device Page.
Overheating
The computer gets hot to the touch and shuts down.
Debris in Air Ducts and Fan
Computers can become excessively hot due to debris stuck in the fan or air ducts. Properly wiping down the air ducts and fan will solve this issue. Another problem that may arise is the fan stops working. To replace the fan use the fan replacement guide: Fan Replacement.
Spencer
crwdns2935283:009/22/14crwdne2935283:0
278 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-1, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 4-1, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S4G1
mine works with 1gb of ram, it is slow of course but that’s it. when i add more ram, 1 or 2gb, it randomly turns off. i have tried to put a fan to the processor when more than 1gb of ram is used but it still seems to overheat and will randomly turn off any time.
pn217dh - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Holaaaaaa
Necesito soporte de este modelo
La pc enciende y todo pero cuando estoy haciendo uso de algún programa se me pone en oscuro nosé porque
deyner190@gmail.com
+505 85797667
Deiner Lopez - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 1,503
