crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Bluetooth Is Not Connecting
The controller’s bluetooth will not connect to your console.
Bluetooth Receiver Not Connecting
If your console says your controller is not connected by Bluetooth, use this guide to ensure you connect it correctly.
Compatibility Issues
This controller is only compatible with Switch, Android 8.0 or above, iOS 13 or above, and Windows 7/10 or above.
Buttons/Joystick Do Not Work Properly
The buttons/joystick will not work after extended use.
Stick Buttons
If there is dirt build-up in the buttons’ crevices, then the buttons become sticky. In order to unstick them, use a cotton swab with rubbing alcohol to clean the crevices of the buttons.
Buttons/Joystick Have Fallen Off Due to Overuse
If the buttons or joystick on your controller have fallen off, use this guide to help you replace it.
Device Is Not Charging
The device does not charge after being plugged in
Charging Port is Broken
If you have double-checked to make sure you have plugged your cable in correctly and your controller is still not charging, you will want to then check the charging port on your controller for any dirt in it. You will want to use something small like a toothpick or paper clip to clean any dirt that is in your port.
Charging Cable is Broken
Check your charging cable for any damage. If your charging cable is damaged, it is time to purchase a new cable.
LED Lights Have Gone Out
The LED lights no longer come on after turning the controller on.
Lights Have Died
If the lights on your controller will not come on, try replacing the lights with this guide.
Loose Connection
Your LED lights may have a loose connection in which you will want to make sure all of the lights are tightly twisted in their slots.
Battery Is Not Holding A Charge
The battery dies quickly.
Battery is Dead
If the lithium battery of your controller will not hold a charge, then it is more than likely dead and should be replaced. This guide will show you how to change it.
Part of Controller is Refusing to Turn Off, so the Battery Drains
First, you should use the device’s charger on another device to make sure it is the battery that is the problem. If the charger is working, then something in your controller is draining the battery. You will need to check if your controller has a firmware update. If there is, you should update and check your battery again.
Madison Puckett
crwdns2935283:009/16/22crwdne2935283:0
833 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-4, Virtue Fall 2022 crwdns2935289:0Western Carolina University, Team 1-4, Virtue Fall 2022crwdne2935289:0
WCU-VIRTUE-F22S1G4
crwdns2944067:017crwdne2944067:0
My RT QND LT work can you help me
Mario Blanco - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Que "potenciómetro joystick" sería el reemplapzo del que tiene el mando gamesir T4 Pro y como se realiza el cambio del mismo?
JOSE ANTONIO R P - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Mi problema si alguna me ayudar es que hace 2 días jugaba normal en la Switch y de la nada se desconecto y ya no conectaba más lo quise conectar con el cel y tampoco salía el dispositivo pero no sé podia conectar para nada así por ende pienso q algo pasa con la conexión inalámbrica como lo soluciono gracias
Anonimo Kezuo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 41
crwdns2936753:030crwdne2936753:0 141
crwdns2959996:0crwdne2959996:0 16,834
