crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
While plugged to a charger, are your Edifier W820NB Plus headphones not charging? Use this troubleshooting guide to help diagnose why.
Faulty Charger
If the charger you are trying to use is not working, the headphones will not be able to charge. Try a completely different cable and power brick. These headphones charge using USB-C.
Faulty Outlet
Though, unlikely, it is possible the power outlet that you are trying to use is not providing power properly. Use a different outlet is another part of your house to attempt charging.
Faulty Battery
If none of the other solutions are working the battery may be faulty. Age is the main factor that kills batteries. They slowly lose capacity over time until they cannot hold a charge. Replacing the battery is the only solution. Please refer to this guide.
Broken USB-C Port
The USB-C port on the headphones themselves may be at fault for not charging. It can be replaced by changing the daughter board inside the headphones that connects to the motherboard. This guide will show you how.
Joseph Forziati
crwdns2935283:003/21/25crwdne2935283:0
180 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-7, Botvin Spring 2025 crwdns2935289:0UMass Dartmouth, Team 2-7, Botvin Spring 2025crwdne2935289:0
UMASSD-BOTVIN-S25S2G7
crwdns2936753:030crwdne2936753:0 58
crwdns2942667:0crwdne2942667:0 573
