crwdns2944686:0crwdne2944686:0
If your device is swollen, bulging, overheating, or smoking, DO NOT PLUG IT IN! The battery is almost certainly the cause and should be replaced. You can find a replacement guide and DualShock 4 CUH-ZCT2 Batteries for your controller at iFixit. Whatever you do, please be sure to dispose of your battery properly.
The Basics
  • Power Cycle the Controller: Hold the PlayStation button to turn off the controller and then turn it back on. Sometimes, a simple power cycle can resolve minor issues.
  • Make sure the controller is charged. If it does not show any signs of life, try charging it for 15 minutes. Look for any indication that the controller is charging (e.g., lights on the controller).
  • Try plugging the controller into the console. Attempt to use your controller while it is plugged into your console. Often, this can indicate an issue with the controller hardware and helps us determine if the controller is experiencing an issue with the internal battery.
Minor Software Issue
If re-syncing the controller with the system didn't work, you can manually reset the controller:
  1. Locate the small reset button on the back of the DS4 near the L2 button.
  2. Push the button with a small, pointy object, such as an unfolded paper clip (or a similar object). The button is in a tiny hole next to the top right screw on the bottom outer shell.
  3. Hold the button down for several seconds, and release.
In addition, updating your controller firmware can also resolve many different issues.
  1. Connect the controller to the PS4 using a USB cable.
  2. Go to Settings > Devices > Controllers > Update System Software.
  3. If there is an update available, then you should update. This will resolve temporary issues with your controller's software and help your controller with issues turning on.
Major Hardware Issue
If you cannot resolve the issue by updating your controller's firmware, the issue might be caused by your controller's physical hardware.
Maaz Hussaini
crwdns2935283:001/21/14crwdne2935283:0
6,038 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-21, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 6-21, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S6G21
crwdns2935297:086crwdne2935297:0
crwdns2936751:024crwdne2936751:0 20
crwdns2936753:07crwdne2936753:0 119
crwdns2936753:030crwdne2936753:0 564
crwdns2942667:0crwdne2942667:0 11,789
