Soap pods not dissolving can be incredibly frustrating. Follow the steps below to work through the most likely causes and culprits.
Incorrect Cycle Selection
Different wash cycles operate at different temperatures.
  • Select the appropriate wash cycle for your detergent.
Water Temperature too Low
Additionally, your water temperature may be too low. Dishwasher pods are designed to dissolve and activate at specific water temperatures.
  • Run your sink hot water before a dish load to keep the cycle to temperature.
  • Verify your sink hot water is set to the dishwasher manufacturer's recommended level, usually between 120°F-140°F (49°C-60°C).
    • If it's too low, increase the temperature on your water heater.
Operator Error
Overloading the Dishwasher
If you overload the dishwasher with too many dishes or overcrowd the utensil holder, it can obstruct the water flow and prevent the pod from dissolving properly.
  • Load the dishwasher according to the manufacturer's instructions.
  • Leave enough space for the water to circulate freely.
Incorrect Pod Placement
Improper placement of the dishwasher pod can also affect whether it can fully dissolve. Most dishwashers have a dispenser or separate pod dispenser in the main wash compartment.
  • Place the pod in the correct compartment.
Dishes Pre-Washed
If you rinse your dishes before placing them in the dishwasher, the soap pod may not dissolve properly because it's designed to work with food particles.
  • Wipe most of the food off dishes, but leave enough residue for the soap pod to interact with the dirty dishes as intended.
  • Pre-rinsing wastes a lot of water.
Faulty Dispenser or Dispenser Blockage
Faulty Dispenser
The detergent dispenser in your dishwasher may be faulty or malfunctioning. If the pod is not opened or released appropriately during the wash cycle, the pod won't dissolve as intended.
  • Inspect the dispenser for damage or obstructions.
  • Replace if necessary.
Dispenser Blockage
The detergent dispenser could be blocked or clogged, preventing the pod from releasing properly during the wash cycle.
  • Check the dispenser for debris, residue, or obstructions, and clean thoroughly.
    • That's correct; your soap dispenser may need cleaning.
Poor Detergent Quality, Old or Expired Pods, Improper Pod Storage
Different dishwasher detergents may have varying abilities to dissolve and clean.
Old or Expired Pods
Dishwasher pods have a shelf life. They may lose their effectiveness and fail to dissolve properly when old or expired.
  • Check the expiration date on the packaging, and use fresh pods.
If you're storing your dishwasher pods in a humid or moist environment, they may absorb moisture and become clumpy, making them less likely to dissolve properly.
  • Store the pods in a cool, dry place away from excessive moisture.
Water Supply Issues
Water is too Hard
Hard water can interfere with the effectiveness of dishwasher pods. The minerals in hard water can form a film or residue on dishes, making it difficult for the soap pod to dissolve.
  • Use a water softener or a dishwasher detergent specifically formulated for hard water.
  • If you have a water softener system in your home, verify it functions.
Water Pressure Issues
Low water pressure could be affecting how much water is entering your dishwasher. You can check your water pressure by following these steps.
  • Pull the machine away from the wall.
  • Disconnect the water inlet valve from the water supply.
  • Open the water supply valve and see if the pressure is at least 20 psi.
  • Call a plumber if the water pressure seems low.
Faulty Spray Arm
If the dishwasher's spray arms or jets are clogged with food and other debris, the water may not reach the soap pod effectively, preventing it from dissolving.
  • Inspect the spray arms and ensure they are free from debris or obstructions. Clean them if necessary.
  • If there are cracks in the spray arms, replace them.
Circulation Pump Failure
The circulation pump moves water from the bottom of the dishwasher back up and through the spray arms. Water doesn't reach and dissolve the soap pod when this pump fails.
  • Test the circulation pump by starting a cycle or initiating a diagnostic mode.
  • Open the door after the water has filled, and see if water is dripping from the spray arms and if the spray arms are spinning.
  • If there is a pool of water at the bottom of the dishwasher, your circulation pump is likely faulty. Remove and test the pump with a multimeter before replacing it.
Dishwashing Tips
Your dishwasher was designed to run with a specific soap and needs cleaning periodically. Performing a routine dishwasher cleaning will help it run in top shape.
Dishwasher Won't Drain
Dishwasher Not Cleaning
Dishwasher Not Drying
Dishwasher Won't Turn On
Dishwasher Stops Mid Cycle
Dishwasher Leaking
How do I get an awful, rotten smell out of my dishwasher?
Additional Resources
nicO
crwdns2935283:004/14/15crwdne2935283:0
15,990 crwdns2915208:0crwdne2915208:0
crwdns2935297:088crwdne2935297:0
Global Fixers crwdns2935289:0Global Fixerscrwdne2935289:0
Community
crwdns2931471:072crwdne2931471:0
crwdns2935297:03,060crwdne2935297:0
Typically this error occurs when either:
1) the wash program is being interrupted (see page "Dishwasher Stops Mid Cycle")
2) the water isn't being heated (thermostat or thermal sensor - typically in the lower bowl , or heater element, or control board)
3) the water isn't being pumped into the water jets (blockage, water pump, control board failure)
granted3 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 53
crwdns2936753:030crwdne2936753:0 335
crwdns2959996:0crwdne2959996:0 18,423
