If your dishes are still dripping wet after a wash cycle, first check your dishwasher’s owner’s manual to make sure it’s being operated correctly. Many manufacturers recommend using a liquid rinse aid for proper drying performance. Additionally, if your home’s water temperature isn’t hot enough to begin with this can hinder drying performance—so adjust the temperature setting on your water heater if needed.
But if none of that helps, there may be an actual hardware issue with your dishwasher. In that case, check the following.
Faulty Vent Door
Your dishwasher likely has a small motorized door or flap that’s supposed to open during the drying cycle in order to vent the steamy air out. Look around for the door and make sure it’s not damaged or obstructed. If necessary, replace it.
Faulty Vent Fan Motor
The vent fan blows the steamy air out of the aforementioned vent. If the vent door is opening properly but the fan motor has failed, most of the steamy air stays trapped in the dishwasher. Remove the fan motor and use a multimeter to test it for continuity. If there’s no continuity, replace the motor.
Faulty Heating Element
The heating element lies inside your dishwasher near the bottom, and helps get the water hot enough to turn it into steam so the aforementioned fan can blow it out and leave everything inside nice and dry. If the heating element fails, the water never gets hot enough to evaporate.
To check the heating element, run a wash cycle using the heated dry feature, and open the dishwasher door in the middle of the dry cycle. (Watch out, it may be very hot in there.) It should be steamy hot inside, and if you wave your hand over the heating element (without touching anything!), you should be able to feel the heat coming off it.
If there’s no heat, you may need to replace the heating element—try removing it from the dishwasher and then use a multimeter to check the resistance of the heating element. It should measure somewhere in the range of 8-30 ohms. If resistance is infinite, replace the heating element.
Faulty Support Components for Heating Element
If the heating element checks out, you may have a heating element wiring failure, thermostat failure, limit switch failure, or control board failure.
Unplug the power to the dishwasher and shut off the water supply, disconnect the drain plug (remembering to use a drain pan), disconnect the water supply (use that pan again), and pull the dishwasher out from the wall. Disassemble the dishwasher enough to check the wiring connections to the heating element and make sure they’re tight.
Check the wiring to the thermostat in the same way. Remove the thermostat and test it with a multimeter—resistance should measure near zero ohms. If not, replace the thermostat.
Your dishwasher may also have a limit switch, which is a safety feature designed to switch off the heating element if it gets too hot. If the switch fails, the heating element may not turn on at all. Remove the switch and test it for continuity; if it fails, replace it.
If none of that helps, you may need to replace the electronic control board for the heating element.
Questions other people have asked about this
Similar dishwasher problems
Dishwasher Won't Drain
Dishwasher Smells Bad
Dishwasher Not Cleaning
Dishwasher Won't Turn On
Dishwasher Stops Mid Cycle
Dishwasher Leaking
Jeff Suovanen
crwdns2935283:008/06/13crwdne2935283:0
455,136 crwdns2915208:0crwdne2915208:0
crwdns2935297:0259crwdne2935297:0
Staff
crwdns2935297:072,810crwdne2935297:0
I had a Sears dishwasher that quit drying the dishes. I knew that taking it apart was going to be a chore so I researched the problem online. Everyone said the heating element was faulty. I bought a new heating element for about $15. I took the dishwasher apart and removed the heating element. I compared the resistance of the old element with the new one and the resistance was 13 ohms vs. 15 ohms. I knew then there was nothing wrong with the element. I traced the wires where the element connected in the back of the dishwasher to a circuit card mounted in top of the dishwasher. There was a burned spot on the back of the circuit card where a relay was soldered. I bought a circuit card from our local appliance parts store for $140 and replaced the burned out circuit card. The dishwasher worked normally after that.
rodriguezjoe3 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 86
crwdns2936753:030crwdne2936753:0 384
crwdns2942667:0crwdne2942667:0 23,111
