Computer won’t turn on
Computer fails to boot up.
Faulty power supply
Make sure that the power cord is firmly connected to the computer and also to the electrical outlet.
Check to see that there is power in the electrical outlet and that a circuit/fuse has not been switched off.
If there still is no power the power supply may need to be replaced.
Computer shuts itself down
Computer will shut down at random.
Faulty power supply
Use a vacuum cleaner with a brush attachment to gently remove dust from the device.
CPU is not powerful enough
Install an additional cooling fan.
CPU is not seated properly
Place the CPU on a firm, level surface which also provides adequate ventilation.
Heat-sink may not be secure or level
Make sure the paste holding the heat-sink is secure.
Heat-sink fan may be dirty
Use a vacuum cleaner with a brush attachment to gently remove dust from the device before it is installed.
Drive fails to read disc or disc skips
Disc drive won't read CD-ROMs, discs skip.
Incompatible disc
Check that the disc is compatible with your drive. While newer drives can read (and write) CD-ROMs as well as DVDs, your model may only read CD-ROMs. For more information on optical drive troubleshooting, see Optical Drive Troubleshooting.
Dirty disc
If the disc is visibly scratched or dirty, this is likely the problem. If you haven’t already, try cleaning the disc with a bit of window cleaning solution and a soft cloth. To be sure it’s not something worse, check to see if your computer will read a different disc. For more information on optical drive troubleshooting, see Optical Drive Troubleshooting.
Bad optical drive
If none of the solutions above seem to work, it’s time to replace the optical drive (link to guide).
The PC freezes while booting up
The PC turns on but does not boot up or load the operating system.
Cables and wires not secured
Turn the PC off and unplug it. Open the case and check that all cables and wires are plugged into the motherboard securely.
Close the cover, plug in your PC and try turning it on again. If you still have the issue, please see the next solutions.
RAM not seated properly
Failure to startup can sometimes be attributed to loose or damaged RAM modules. A good indication of this might be a series of beeps sounding when you turn on the PC. If the PC emits two short beeps, one or more RAM modules may need to be reseated into the motherboard. In some cases, the RAM may need to be replaced.
Please refer to the RAM installation guide for more information on removing and replacing RAM modules.
CPU and/or heat sink not seated properly
If the RAM is seated properly but you still cannot get the PC to boot without freezing, it may be a problem with the CPU or the heat sink.
First, check the heat sink and fan. If the heat sink is crooked or not secure , it will not cool the CPU effectively. Likewise, if the fan is clogged with dust it will not be able to disburse heat.
If the heat sink is secured and the fan appears to be clean, the CPU may be loose or require reseating. Please refer to the CPU replacement guide for tips on how to get access to these components.
Programs keep crashing or freezing
The computer boots up and the operating system loads, but programs don’t seem to work properly.
Insufficient RAM
A frozen or sluggish PC can most likely be attributed to insufficient levels of RAM. You may need to replace one or all modules with RAM of a higher capacity.
Faulty RAM
If you know you have enough RAM, then you may have faulty modules. If you have more than one stick of RAM installed, take all modules out and try each one individually.
The PC doesn’t run as fast as it used to
The computer no longer loads programs quickly or experiences extreme lag time.
Hard drive data is fragmented
Pockets of empty space exist on the hard drive causing slow access times. This empty data must be moved to the end of the disc by using a disc defragmenting program on the computer.
Insufficient RAM
Please refer to the RAM installation guide for more information.
Wasted RAM usage
If you have a lot of programs running, this may slow your computer down. Try closing any programs that you aren’t using.
Computer virus
If very few or no programs are running, you may have a computer virus or malware. Viruses and malwarerun in the background undetected and use up a lot of system resources. Try running an antivirus or antimalware software program.
Lagging video or poor image quality
Images and colors display slowly or incorrectly.
Check monitor cable connection
Make sure that the cable connecting the computer to the monitor is secure at both ends. Gently twist the screws on either side of the cable heads to ensure a good connection.
Bad display settings
Check the display settings on your computer.
Bad graphics card
If all else fails, you probably need to replace the video card.
Jill Shastany
crwdns2935283:009/21/13crwdne2935283:0
218 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 crwdns2935289:0UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013crwdne2935289:0
UMASSD-GULBRANDSEN-F13S1G2
crwdns2935297:084crwdne2935297:0
crwdns2959996:0crwdne2959996:0 8,258
