Optical Drive Troubleshooting
Optical drives generally work or they don't. Assuming the drive is installed and configured properly initially, it should be problem-free throughout its service life.
Use the following guidelines to troubleshoot optical drive problems:
  • When an optical drive behaves strangely, the first step is to reboot the system.
  • Gross failures, such as the computer BIOS not detecting a drive that formerly worked normally, are usually caused by an outright failure of the drive itself. If you've recently worked inside the system, the most likely cause of a complete drive failure is that you left the power or data cable disconnected or that you damaged the data cable.
  • If you install an SATA hard drive in a system that was previously all PATA and the optical drive "disappears," make sure that the operating system is fully updated. Older ATA drivers sometimes become confused if SATA and PATA devices are used together. Windows 2000 and Linux distributions that use a kernel earlier than 2.6.11 are particularly subject to this problem.
  • If you experience read errors, try a different disc, or clean the current disc. If read errors occur with different discs, use a cleaning disc to clean the drive.
  • If a DVD drive refuses to read CDs but will read DVDs, or vice versa, the mostly likely cause is that one of the two read lasers has failed. Replace the drive.
  • If an optical writer fails while burning the first disc of a new type of disc or a new batch of your usual type of disc, update the drive firmware. Check the manufacturer's support site to see whether a firmware update is available for download. If not, call their tech support number and ask.
  • If the firmware update doesn't solve the problem, try a different brand of disc, preferably one that is recommended by the maker of your optical burner.
Cleaning an optical drive
The first symptom of a dirty optical drive is that you get read errors on a data CD or DVD or degraded sound or video from an audio CD or DVD-Video disc. If this happens, it is often because the disc itself is dirty or scratched, so clean the disc or try a different disc before assuming the drive is at fault.
Tray-loading optical drives require little cleaning. They are well sealed against dust, and all recent drives incorporate a self-cleaning lens mechanism. For routine cleaning, wipe the external parts of the drive occasionally with a damp cloth. Some drive makers recommend using a drive cleaning kit every month or two, although we usually do so only when we begin getting read errors. To use these kits, which are available in wet and dry forms, insert the cleaning disc and access the drive to spin the cleaning disc for a few seconds. For a particularly dirty drive, you may need to repeat the cleaning process several times. Slot-loading optical drives can be cleaned more thoroughly by vacuuming the interior gently, using a pencil or similar object to hold the slot open, or by using compressed air to blow out the dust and then drenching the interior of the drive with zero-residue cleaner. Most optical drive manufacturers discourage taking more extreme measures, so if you go beyond these routine cleaning steps, you are on your own and may void your warranty.
Updating drive firmware
For any optical drive, but particularly for optical writers, it's important to keep the firmware updated. Firmware updates fix bugs, add features, and add support for new brands and types of optical discs. We generally update the firmware in our optical drives every time we buy a new spindle of discs.
If you're running Windows, visit the manufacturer's web site periodically, and download the latest firmware version for your drive. Most optical drive makers supply firmware updates as executables that can be run directly from Windows or from a command prompt. Verify that there is no disc in the drive, and then just run the executable to update your drive firmware.
Figure 8-9 shows a typical firmware update utility, in this case one for the Plextor PX-716A DVD writer.
Figure 8-9:  A firmware update utility for the Plextor PX-716A DVD writer
If you are running Linux, updating your drive firmware may be problematic. All drive makers supply firmware updaters for Windows. Many also supply OS X updaters. None we know of provides updaters for Linux. If you're dual-booting Linux and Windows, there's no problem. Simply boot Windows and install the Windows version of the firmware update.
But if you're running only Linux, you'll have to jump through a few hoops to get your drive updated. We run Linux on all of our production systems, so we encounter this problem frequently. The best solution is usually just to bite the bullet, pull the optical drive from the Linux box temporarily, connect it to a Windows box, and do the update from there.
Determining drive capabilities
Sometimes, an apparent error isn't an error at all. For example, if your optical drive refuses to read, write, or even load a particular type of disc, it may be that the drive simply wasn't designed to accept discs in that format. To determine the capabilities of your optical drive, use Nero InfoTool, shown in Figure 8-10. You can download a free copy of Nero InfoTool from http://www.nero.com.
Figure 8-10:  Nero InfoTool displays drive capabilities
In our case, the DVD-ROM drive in one of our test-bed systems spit out a DVD+R DL disc someone had sent us. We weren't sure if the problem was the drive, the type of disc, or the individual disc itself. Running Nero InfoTool told us: the drive simply didn't support DL media.
Nero InfoTool also comes in handy when you want to update the firmware in your drive. Some optical drives have no indication of manufacturer or model on the front panel. For example, we decided to upgrade the DVD-ROM firmware to see if the new firmware would add read support for DVD+R DL discs. We thought the unlabeled DVD-ROM drive was a Samsung model. When we ran Nero InfoTool, it listed the drive as an XJ-HD166S, which is a Lite-On model. It's a bad idea to install a firmware update intended for one model of drive to a different model, so ordinarily we'd have had to open the system and remove the drive to verify its model. Instead, we ran Nero InfoTool to find out.
We visited the Lite-On site and downloaded the most recent firmware for the drive, which was version DS1E, six versions later than the DS18 firmware currently installed. We ran the firmware update executable and rebooted the system. When we again ran Nero InfoTool, we were pleased to see the change shown in Figure 8-11. Yep, with the firmware update, this drive now reads DVD+R DL discs (although still not DVD-R DL discs).
Figure 8-11: Nero InfoTool showing the new firmware's capabilites
Verifying quality of burned discs
If you have problems reading a burned disc, the first step is to determine whether the problem is caused by the disc or by the DVD drive or player. Most disc burning applications have a verify feature, but a disc can verify successfully in the drive that burned it and still produce read errors in DVD-ROM drives and players.
If you use high-quality writable discs in a good burner, the disc will seldom be the problem. Still, it's easy enough to check disc quality by doing a surface scan of the burned disc. If you use a Plextor burner, you'll have PlexTools, which can provide more information about disc quality than you ever wanted to know. If you use another brand of burner, download the free Nero CD-DVD Speed utility (http://www.cdspeed2000.com).
It's important to use a high-quality DVD-ROM drive to do the scanning, such as one made by Lite-On, Pioneer, NEC, Plextor, or Samsung. To scan a questionable disc, insert it in the DVD drive, start Nero CD-DVD Speed, click the ScanDisc tab, and then click the Start button. Figure 8-12 shows the results from scanning a "perfect" DVD. If there are damaged but readable areas on the disc, they'll be flagged in yellow. Unreadable areas are flagged in red.
Figure 8-12: Nero CD-DVD Speed displays a perfect disc scan
We put "perfect" in quotes because few burned optical discs are truly perfect. Running utilities such as PlexTools or Kprobe on nearly any burned disc will find C1/C2 errors (CD) or PI/PO errors (DVD). If the disc has passed a standard surface scan, those errors are generally insignificant. For example, Figure 8-13 shows the result of scanning the same disc shown in the preceding graphic, but with the C1/C2 PI/PO scan option. Despite the errors shown, this disc is perfectly usable for all practical purposes. We suggest you restrict yourself to standard scans, and leave the highly technical detailed scans to the engineers.
Figure 8-13: Nero CD-DVD Speed displays errors on a PI/PO scan
Dealing with Book Type issues
It's not uncommon for burned DVDs that read perfectly in one drive or player to be unreadable in another drive or player, often an older model. Sometimes, the problem is simply a matter of the age of the drive or player. Older read heads may not deal well with some types of discs that were introduced after the player was built, because the newer discs have lower reflectivity and contrast than the pressed DVDs for which the drive or player as designed. For example, most DVD drives and players made before mid-2004 cannot read DVD+R DL discs, although this problem can sometimes be fixed by installing a firmware update. Similarly, many DVD players made before about 2002 will load DVD-R or DVD+R discs, but the playback is jerky and filled with video and audio artifacts.
A complete failure to read is often caused by the Book Type field. This field is a half-byte (4-bit) string at the beginning of the physical format information section of the control data block that exists on every DVD, pressed or burned. The purpose of the Book Type field is to identify the type of disc unambiguously so that the the drive or player will know how best to play it. Table 8-1 lists the possible values for the Book Type field.
Table 8-1: Book Type field values
If the playback device does not recognize the Book Type field value either because the drive or player predates a new type of media or because the manufacturer intentionally failed to provide support for particular media types one of two things happens:
  • The playback device makes a best-effort attempt to play the disc. This attempt is usually at least partially successful, and this is the default method used by most current and many older DVD drives and players. Older players and drives may produce read errors and other glitches when attempting to read newer types of discs, but at least they make the attempt.
  • The playback device refuses to attempt to read the disc, even if there is no technical reason for doing so. Some DVD drive and player manufacturers refuse to support formats, such as DVD+R and DVD+RW, that are not officially recognized by the DVD Forum. When a disc of an unsupported type is inserted, these drives and players simply eject it, without attempting to read it.
As a workaround, some DVD writer makers have enabled a feature in their firmware called compatibility bit-setting. A drive that supports this feature can record DVD+R, DVD+RW, and DVD+RW DL discs with the Book Type field set to 0000. In other words, these drives lie to the playback device by causing the discs they write to report themselves as DVD-ROM discs.
Some DVD writers automatically write any "plus format" disc with the Book Type field set to identify the disc as a DVD-ROM. Other DVD writers support compatibility bit-setting, but make using it optional (and require that the burning software explicitly support the feature). Still other DVD writers do not support compatibility bit-setting. Plextor, for example, long refused to support this feature (although their PX-740A does support it). If you need compatibility bit-setting, make sure that any drive you install explicitly lists support for that feature, and, if necessary, that your burning software also supports it.
Our opinion is that compatibility bit-setting is pretty much obsolete. In an era of $25 DVD players and $40 DVD writers, it makes more sense just to replace older, incompatible hardware with newer models that eliminate the compatibility issues.
More about Optical Drives
crwdns2935291:0crwdne2935291:0
Sam Goldheart
crwdns2935283:010/18/12crwdne2935283:0
478,968 crwdns2915208:0crwdne2915208:0
crwdns2935297:0538crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:072,966crwdne2935297:0
crwdns2944067:04crwdne2944067:0
as an Engineer I am on a tight budget. so I can't afford to just blow $$ on a new drive anytime I like. that's wasteful, when it would require just some time and effort to make the drive compatible. firmware updates handle new media models.
it is also better stewardship of this planet we are on.
that bit about drive firmware updates only being a side note with regards to lower writing levels and replacing the drive as being preferable I think is wrong. you admitted it yourself, really it's just a firmware update!
simply update the firmware or request a firmware update from the manufacturer to be created that handles the disc model in question, and wait. give them the vendor/make and model number of the disc(s). this way, you help others out too. my drive' spec lists LTH discs, but none none are listed in the drive compatibility list because LTH discs came out after the drive, and the company that sells my media was saying that you must check the compatibility list to make sure it supports them.
jmichae3 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I must say that canned air works pretty good usually if drive is off and tray is ejected and as for the zero-residue cleaner, I would avoid that, since if it is a cleaner/degreaser (great for electronics), that's a bad idea since there is grease on the skids and on the gears that make the drive open, and the degreaser (or cleaner?) could make the grease melt and go away - you know what detergent does to grease on pans... same concept. then the tray would jam or move with more difficulty.
you could use the cleaner/degreaser like Blue Shower on the green printed circuit (electronics) board. but on the lens if I had to I would use Purosol Optical Plasma lens cleaner (USA) if you need to go that far, or use a lens duster for a camera? I don't mind taking the drive apart to get the dust out.
pressing hard on canned air makes -60deg freeze spray - some say the thermal shock (difference between hot and cold areas on the same board I assume) can crack solder joints, etc. but this doesn't seem to happen a lot.
I should say avoid doing the freeze spray thing - not good for electronics in general unless you are trying to cool something really hot down really fast. take a few practice sprays. and use the stuff outdoors if you can, the gas is heavier than air and it can get stuck in your lungs and make it hard to breathe (also, if using in a room, avoid crawling on the floor).
anyone know about drives getting hacked after using free or sample ware burning software?
i seem to recall the drive started spitting out dvds incessantly when i was trying to go online to a site and the burning softwRe was open. disc was in blank that is and now i had to reset smc
the cds will insert the dvd is wishy washy
i will say dvd less or regular one layer read or mount fine
just the dual layer of blank or store bought dvd dl content like say ‘blade runner 2049’
it keeps spitting it out
this seems to be hacked!
how can i tell?
i do not trust any websites now with freeware that tries to sell you after you have it on your mac
this is a mac
makinfilms - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 17
crwdns2936753:07crwdne2936753:0 59
crwdns2936753:030crwdne2936753:0 273
crwdns2959996:0crwdne2959996:0 51,951
