Won't turn on
If pressing the power button does not appear to turn the device on check the battery then check the screen and keypad.
Replace the battery
See the section "battery won't charge" to test or replace the battery.
Check the screen and keypad
If the keypad lights up when you start the phone but the screen does not light up the screen is probably faulty.
Battery won't charge
This issue may be due to a faulty battery or a faulty charger.
Buy replacement battery
To determine if the battery is faulty install it in the phone and attach the charger. Let the battery charge for 20 minutes then remove the charger and try to start the phone. If the phone does not start the battery is probably faulty. Replace it with Sony Ericsson battery from Amazon.
See Sony Ericsson W518a Battery Replacement.
Buy replacement charger
If the battery appears to be faulty remove it from the phone and reattach the charger. Try to start the phone. If the phone does not start the charger is probably faulty. Replace it with Sony Ericsson Charger from Amazon.
Black screen
Check the battery
Replace the screen
If the screen was determined to be faulty in the above replace the screen with on taken from another Sony Ericsson W518a.
The keypad doesn't work
If the keys do not work replace the keypad with one from another Sony Ericsson W518a.
see Sony Ericsson W518a The keypad Replacement.
Poor quality pictures
see Sony Ericsson W518a Camera Lens Replacement.
Clean the lens
Clean the inside and outside of the lens with a microfiber cloth.
Replace the lens
If the cleaning the lens does not resolve the issue, try replacing it with one that was taken from another Sony Ericsson W518a.
Replace the SIM card
If you need to transfer the SIM card and install a new SIM card into the phone see Sony Ericsson W518a SIM Card Replacement.
Replace the face plate
If you want to replace the faceplate or install a new one see Sony Ericsson W518a Faceplate Replacement.
kgkramer
crwdns2935283:006/27/12crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-5, Regan SU 2012 crwdns2935289:0Cal Poly, Team 1-5, Regan SU 2012crwdne2935289:0
CPSU-REGAN-SU12S1G5
crwdns2959996:0crwdne2959996:0 3,010
