In this guide the back housing of the phone will be removed and the camera lens will be removed from the housing.
Find the small notch on the side of the phone. The notch is located by the "fast-forward" button and the "lock" switch.
Insert your plastic opening tool into the notch.
Pry off the faceplate by gently sliding the plastic opening tool around the phone while still keeping the tool under the edge of the phone.
When enough of the faceplate has been lifted it can be easily removed.
Remove the four 2mm Phillips screws from the back housing of the phone.
Insert the plastic opening tool in the notch at the top corner of the phone.
Lift the corner and run the plastic opening tool around the phone until the back housing can easily be removed.
Remove the lends by pushing the lens from the inside of the housing.
