crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Internet not connecting
BrightSign 4K does not connect to internet.
Loose ethernet cable
The BrightSign player cannot connect to the internet if the cable is loose. Try to unplug the Ethernet cable from the BrightSign player and the modem/router. Wait 5 seconds then plug it back in. You should also try to connect with another Ethernet cable if the current one still doesn't work.
Ethernet port is broken
The Ethernet port on the BrightSign 4K might be broken. Unplug the Ethernet cable from the BrightSign 4K and try it on another device that also uses internet. If the internet does work on that device then it is the problem with the Ethernet port of the BrightSign 4K and it needs to be replaced.
Modem and/or router fails to provide internet
If you still cannot connect to internet, your modem/router may be broken. First turn off the BrightSign 4K and the modem/router. After 30 seconds, turn the modem/router back on. Wait until all the lights of the modem/router are on then turn on your BrightSign 4K. The Wi-Fi LED light on the BrightSign 4K should be flashing when it is connecting to Wi-Fi. If you connect via an Ethernet cable, then the Ethernet (Eth) LED light should be flashing. The Wi-Fi (or Eth) LED light should be stable when the BrightSign player is connected to the internet. This guide will show you how to locate and read each LED light on the BrightSign 4K. If you still cannot connect, there may be problems with your service provider.
Problems with device storage
Old cached MRSS not being deleted.
Device fails to read SD card
If the device comes back with no memory card inserted take the card out, and reinsert it. Double check to make sure the memory card is in the right formatting on the software by going to step 2. If this does not work follow this memory card port issue.
Memory card not storing new files
When receiving the device this software should be on your PC.
If your Brightsign 4k Media Player is not playing content, check to make sure your memory card is not full. If the 8GB memory card is full, pull it out. Delete all the files in the cached history, reinsert the memory card, and reboot the media player system. If this does not work, go to Exchaning Memory Card below.
Damaged SD card
Properly remove and replace an SD memory card.
First locate the BrightSign player and power connection. After disconnecting the power, remove the memory card located on the side by simply pressing to eject. Insert your new 8GB memory card and restart the system.
[Link will be provided]
Device overheating
The device is hot, and will not turn on or run.
Dusty Air Vents
If you look at the vents, and see that there is dust then you might need to just wipe down the sides with a duster. If you see smoke coming from the vents, or dusting off the device did not help look at "Heat sink".
Internal components overheating
When seeing smoke coming from the vents a look at the inside will help out.
Problems with video quality
The quality of your playback is lower than expected quality.
Test device image
Please visit the website BrightSign and click "Sample Video Content" to download the sample video content from BrightSign website and compare it to your device to determine the actual problems.
Poor video quality
Please follow the instructions on the website Optimizing Video Quality page for possible problems. This website provides necessary steps for getting the best quality on your BrightSign device.
Problem with the file or a bad encode
Try re-encoding the video or using a different application to encode the video.
Problems with audio quality
You have trouble listening to the sound from the BrightSign player.
Problem with the file or bad encode
Try re-encoding the audio or video, or using a different application to encode the video.
Problem with flash card speed
If the BrightSign is using high bitrate video (20Mbps or more), it is possible the flash card is not fast enough to keep up. Try encoding at a lower bitrate.
Audio drops out, hiccups or distortion
For MPEG-2 files, open your video using the Mpeg2VCR utility, and save it. Some videos have uneven distribution of audio and video packets in the MPEG stream. Users can download a 30-day trial of Mpeg2VCR from "Womble."
Zackery
crwdns2935283:002/15/18crwdne2935283:0
347 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S17-G6, Boczar Spring 2018 crwdns2935289:0USF Tampa, Team S17-G6, Boczar Spring 2018crwdne2935289:0
USFT-BOCZAR-S18S17G6
Hey Zackery, I've setup an XD233 4k player in Local File Network option. When I open the folder with the videos, all the videos are showing as broken links. The jpeg files are ok. Can you say what may be causing this and how to fix it?
I'm trying to add a screen shot here but not seeing an option for that.
Please advise. thanks
Joey Sukhdeo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 1,909
