iBook G3 12" Bottom Shield Replacement
    1. iBook G3 12" Bottom Shield Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a coin to rotate the battery locking screw 90 degrees clockwise.
      • Lift the battery out of the computer.
    1. iBook G3 12" Bottom Shield Replacement, Lower Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Your laptop should look approximately like this.
    2. iBook G3 12" Bottom Shield Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
    3. iBook G3 12" Bottom Shield Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the three 5.2 mm newly-revealed Phillips screws.
    4. iBook G3 12" Bottom Shield Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
    5. iBook G3 12" Bottom Shield Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the one 10 mm and two 20 mm hex screws using a 2mm hex. Alternatively, a T8 Torx screwdriver key will do.
    6. iBook G3 12" Bottom Shield Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 4.2 mm Phillips screws on either side of the battery contacts.
    7. iBook G3 12" Bottom Shield Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
      • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
    8. iBook G3 12" Bottom Shield Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
    9. iBook G3 12" Bottom Shield Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
    10. iBook G3 12" Bottom Shield Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound out port.
    11. iBook G3 12" Bottom Shield Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
    12. iBook G3 12" Bottom Shield Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
    1. iBook G3 12" Bottom Shield Replacement, Bottom Shield: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    2. iBook G3 12" Bottom Shield Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the five 5.8 mm Phillips screws from the bottom shield.
      • Peel back the yellow tape and foil shielding outlined in the image.
    3. iBook G3 12" Bottom Shield Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the bottom shield off.
crwdns2935229:011crwdne2935229:0
crwdns2955734:0crwdne2955734:0
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 9,292
