Troubleshooting Chart for all beers
These are some of the issues that can occur in a batch of beer, along with the potential issues that could be causing the underlining issue. Use the list below to find the issue with your beer.
Issues and Solutions
Fermentation does not start
  • Not enough yeast pitched
  • Wort too hot (yeast stunned/killed)
  • Wort too cold (yeast dormant)
  • Fermentation is fine, but the bucket is not sealed (so you can’t see bubbles in the airlock)
  • Fermentation already complete (look for a ring of “crud” around the inside of the fermenter)
Stuck fermentation
  • Inadequate aeration
  • Wort temperature too low
  • Yeast strain flocculated early (rousing yeast may help)
  • Fermentation is finished, not stuck (take specific gravity to check)
A buttery or butterscotch-like flavor or aroma
  • The yeast did not absorb diacetyl
  • Contamination
  • Racked beer too early
  • Yeast strain
Overly fruity aromas, especially banana
  • High fermentation temperatures
  • Inadequate pitching rate
  • Yeast strain
Chloraseptic-like or Band-aid-like aroma or flavor
  • Contamination
Vinegar flavor or aroma
  • Contamination. Specifically contamination in conjunction with exposure to oxygen
Stuck mash
  • Running off wort too quickly
  • Grains crushed too finely
  • A high percentage of wheat or rye
Low extract efficiency
  • Crush too coarse
  • Collecting wort too fast
  • Collecting too little volume of wort per unit of grain
  • Poor lauter tun design
  • Water chemistry was not conducive to good mash (check calcium levels first)
  • The pH outside of the 5.2-5.6 range
Overly high final gravity
  • Maybe the beer was supposed to have a high FG
  • A high percentage of specialty malt in the recipe
  • Yeast strain
  • Any of the causes listed under “Stuck fermentation
Chill haze
  • Use Irish moss (at a rate of 1 tsp. per 5 gallons)
  • Boil too short or not vigorous enough
Poor foam
  • Glassware dirty
  • Weak fermentation
  • Too little protein in wort (esp. when high amounts of adjunct are used)
Mold on the surface of the beer
  • It may be yeast, not mold (different yeast strains can behave differently)
  • Wort is exposed to oxygen, which encourages surface growth
Bottle-conditioned beer is flat
  • Move bottles to a warmer location for conditioning
  • Give beer more time to condition
  • Beer and priming sugar not adequately mixed in the bottling bucket
  • You forgot the priming sugar
  • Not enough yeast left in beer to bottle condition (this rarely happens)
Bottle-conditioned beer is over-carbonated
  • Contamination
  • Too much priming sugar
Cheesy aroma or flavor
  • Hops are old and stale
Corn-like aroma or flavor (DMS)
  • Wort cooled too slowly when certain very pale malts used
  • contamination
Solvent-like or nail-polish aromas (higher alcohols, fusel oils)
  • Fermentation temperature too high
  • High original gravity
Skunk-like aroma
  • Beer exposed to light (especially due to bottling in clear or green bottles)
Wet cardboard aromas and flavors (oxidation)
  • Beer exposed to oxygen during late fermentation or conditioning
Sherry-like aromas or flavors (oxidation)
  • Long aging of high-alcohol beers (appropriate in some cases)
Excessive sediment in the bottle-conditioned beer
  • Some sediment is always present
  • Let beer fall clear before bottling
Water, wort, or beer leaked on the floor
  • Be sure all valves are closed before transferring liquid to a vessel
  • Check to make sure that the rubber grommets are not worn around your valves
Beer on ceiling
  • The fermentation lock was clogged (use a blow-off tube next time)
Troubleshooting Chart for malt extracts
If you are using a malt extract when brewing, then make sure to check if these are your issues if you are noticing these qualities of your brew.
A puckering, tea-like quality (astringency)
  • Steeped grains in too much water (over 3 quarts water per pound of grain)
  • Steeping water too hot (over 170 °F)
Wort darker than expected
  • Concentrated wort boil
  • Scorching of malt extract (stir in thoroughly)
Beer’s original gravity (OG) is too low
  • Wort and topping up water not mixed thoroughly
Troubleshooting Chart for all grain
If you are using an all-grain brewing process, then make sure to check if these are your issues if you are noticing these qualities of your brew.
  • Excessive volume of sparge water (collected wort less than SG 1.008 or above a pH of 5.8)
  • Excessively hot sparge water (over 170 °F)
Sour or tart beer
  • Mash sat overnight and the temperature dropped to 120 °F (or below)
Poor foam
  • Overly-long rest at 122-131 °F
  • Poor extract efficiency
Jacob Mehnert
crwdns2935283:010/18/21crwdne2935283:0
49 877 crwdns2915208:0crwdne2915208:0
crwdns2935297:052crwdne2935297:0
iFanatics crwdns2935289:0iFanaticscrwdne2935289:0
Community
crwdns2931471:069crwdne2931471:0
crwdns2935297:01 151crwdne2935297:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 808
