crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Fails to Charge
The phone does not turn on when pressing the power button.
Charger Does Not Work
Ensure all cords are connected properly, and the power outlets are functional. If they are, then the charger may is broken; purchase a new charging port.
Faulty Charging Port
Ensure the phone micro USB charging port isn't damaged or has any debris blocking the port. If there is no damage or debris, then replace the charging port .
Faulty Battery
Ensure battery is placed inside correctly and isn’t damaged. If battery is secured but does not work, then battery will [crwdns2936915:0crwdne2936915:0]. If the new battery does not work the battery connector may be damaged and will need to be replaced.
Weak Touch Sensitivity
Screen does not fully function when applying touch pressure .
Touch Calibration Not Set
Reset the touch calibration in the settings. If this does not solve the issue, replace entire screen.
Air Bubbles Under Screen Protector
If the screen protector was applied incorrectly, air bubbles may have formed. Reapply and remove the air bubbles. If this does not solve the issue, forgo the screen protector.
If the screen is visibly damaged or scratched, replace the screen .
Freezing/App Crashing
Application freezing or closing .
Low Memory Space
Check the memory usage on your application in settings. Force stop/uninstall/close any applications under settings that you don't use. Restart the phone to reset the memory. If this does not solve the issue, upgrade the microSD card slot under the back cover with a 64 GB memory card.
Phone Software Not Up to Date
Upgrade to most current software version for the android device.
Weak Call Quality
Connection in calls are low and in bad quality .
Low Service Reception
Poor reception will cause calls not to connect be sure to check with the service provider. If this does not solve the issue, the connection with the antenna is disturbed and you will need to replace the motherboard which is connected with the antenna.
Faulty Top Speaker
Check the speakers and microphones and ensure they aren't covered by dust or debris. Have a person on the opposite end of the phone call check their speakers as well. If this does not solve the issue, replace the motherboard.
Volume is Turned Down
Low volume can be resolved by raising in-call volume to increase the tone of the voice on the line. Using headphones can also fix tone and quality.
Poor Headphone Speaker Quality
Audio quality is choppy, flat, or one-sided.
Damaged 3.5mm Headphone Jack
Clean out the headphone hole from debris that may be trapped inside. If this does not solve the issue, replace the motherboard.
Faulty Headphone Jack Connection to Motherboard
Check that headphones work with other device prior to using on Blu Studio G. The device being dropped/ hit on top where headphone connects may cause soldering to break and will need to replace motherboard.
Christian Perez
crwdns2935283:004/11/17crwdne2935283:0
542 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S1-G3, Rowley Spring 2019 crwdns2935289:0Eastern Washington University, Team S1-G3, Rowley Spring 2019crwdne2935289:0
EWU-ROWLEY-S19S1G3
crwdns2959996:0crwdne2959996:0 855
