Device will not power on
''Use this troubleshooting if your Blackberry will not turn on.
Battery is not installed properly
Remove battery from device and reinsert, then attempt to power on. See the battery replacement guide for any questions on how to complete this step.
Battery has lost charge
This is especially useful if your phone has been off for a long time. It may have lost it's charge. Charge the phone for 15-20 minutes then attempt to the power on the phone.
Battery is bad
If none of the above options work your battery may be bad. Attempt to borrow a battery from a friend or purchase a new one. Purchasing a new battery is only recommended as a final step if previous options have been exhausted. See battery repair guide for any questions.
Logic board may be bad
This step is unlikely but if all other options short of buying a battery have failed and your phone is out of warranty replacing the logic board may be an option. See motherboard repair guide for step by step instructions.
Device has frozen
Reset the phone
Reboot the phone by one of these two steps.
1. Soft reset the phone by pressing ALT + CAP + DEL
2. Remove the battery. Wait for 30 seconds with the battery out. Put the battery back into place and turn the phone on by holding the red call end button.
Screen will not power on
If the phone turns on but no image appears the screen may be faulty.
First, try resetting the phone as described above. If resetting does not work, replacing the screen with the screen repair guide may be an option.
Keypad/Trackpad Issues
Keypad button broken or stuck
You may replace the keypad by following this guide here.
Trackpad is unresponsive or very slow.
Try restarting the phone using both resetting methods.
If neither work, the following guide will explain how to replace the trackpad here
David Hodson
crwdns2935283:004/13/10crwdne2935283:0
156 822 crwdns2915208:0crwdne2915208:0
crwdns2935297:0127crwdne2935297:0
What do I do about seeing the blackberry battery with lightning on it?
DankyMan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My blackberry is the 8530 curve
crwdns2942667:0crwdne2942667:0 9,522
