BlackBerry Curve 8530 Trackpad Replacement
    1. BlackBerry Curve 8530 Trackpad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Curve 8530 Trackpad Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Place the phone on a flat surface with the screen facing down.
      • Remove the plastic backplate by pulling up on the bottom of the cover.
    2. BlackBerry Curve 8530 Trackpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery by pulling up from the top of the battery.
    1. BlackBerry Curve 8530 Trackpad Replacement, Keypad: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Curve 8530 Trackpad Replacement, Keypad: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
      • Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
    2. BlackBerry Curve 8530 Trackpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Curve 8530 Trackpad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the phone over so the keyboard faces up.
      • Insert a plastic spudger into the screen where speaker resides.
      • I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
      • Gently lift up plastic screen cover until screen cover separates from screen.
      • Continue until screen cover is completely removed.
    3. BlackBerry Curve 8530 Trackpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry Curve 8530 Trackpad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry Curve 8530 Trackpad Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up.
      • Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
    4. BlackBerry Curve 8530 Trackpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Curve 8530 Trackpad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The keyboard should slide off of the phone now that the plastic siding has been removed.
    1. BlackBerry Curve 8530 Trackpad Replacement, Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry Curve 8530 Trackpad Replacement, Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry Curve 8530 Trackpad Replacement, Screen: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • To detach the screen, there are two screws at the top of the phone to be removed. Use the T6 Torx Screwdriver to remove the screws.
      • There is a gold ribbon on the top left of the phone. Lift up this ribbon gently until it is detached from the phone.
      • Note: When reassembling, the ribbon should be reattached before replacing the top screws.
    2. BlackBerry Curve 8530 Trackpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry Curve 8530 Trackpad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry Curve 8530 Trackpad Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • There are two clips on each side of the phone. Insert a plastic spudger between the clips and the screen.
      • Use pressure to unlatch the screen from the clips.
      • Now that these clips have been undone, the screen should lift up easily.
    1. BlackBerry Curve 8530 Trackpad Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BlackBerry Curve 8530 Trackpad Replacement, Motherboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Now there are four screws that need to be removed. They are located at the bottom of the phone and can also be removed using a T6 Torx Screwdriver.
    2. BlackBerry Curve 8530 Trackpad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry Curve 8530 Trackpad Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry Curve 8530 Trackpad Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Now the motherboard will lift up out of the plastic backing of the phone.
    1. BlackBerry Curve 8530 Trackpad Replacement, Trackpad: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BlackBerry Curve 8530 Trackpad Replacement, Trackpad: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BlackBerry Curve 8530 Trackpad Replacement, Trackpad: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip over the motherboard.
      • There is another torx screw near the middle of the motherboard on the left side.
      • Using the T5 Torx Screwdriver, remove the screw and the metal casing.
      • Note: Distinguish this screw from the others for reassembly purposes.
      • Detach the clip holding the track pad in.
    2. BlackBerry Curve 8530 Trackpad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the trackpad from the motherboard.
      • Now you are ready to reassemble the phone
Chris
crwdns2935283:004/20/11crwdne2935283:0
227 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-13, Regan Spring 2011 crwdns2935289:0Cal Poly, Team 15-13, Regan Spring 2011crwdne2935289:0
CPSU-REGAN-S11S15G13
No need to full disassemble the phone. Just remove the back and the battery and unscrew the T5 screw, presto 20 minutes saved.
willdickerson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 15,995
