crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Display Not Working
The screen appears black even when the device is on.
Device Battery Drained
Plug the device into the charger. If the device does not immediately turn on, wait at least 30 minutes for the device to charge. Press the power button to check if the device displays anything.
Driver Out of Date
If the device is not compatible with newly updated software, then a driver update may be needed.
Device Needs Rebooting
Press and hold the power button on the side of the device. Wait 30 seconds, then press the power button again.
Damaged Screen
If the device continuously has a black screen, then the screen might be damaged. To replace the screen, follow this repair guide.
Device Not Charging
The battery of the device will not charge when plugged into a charger.
Faulty Charger
Make sure the charger is plugged into the wall outlet as well as the tablet. If the device continues to not charge, then the charger may be damaged. If the charger is damaged, you may need to buy a new one.
Damaged Charging Port
The charging port might be damaged, causing the device to not charge. To replace the charging port, follow this repair guide.
Camera Not Working
The camera will not open or will not allow you to take photos.
Blocked Lens
Check to make sure nothing is blocking the lens. Make sure when you take photos that your finger or other objects are not blocking the lens.
Device Needs Updating
To update the device manually, follow the instructions on this link.
Damaged Camera
If your camera continues to not work, then you may need to replace it. To replace the camera, follow this repair guide.
Device Not Turning On
The device will not turn on after pressing the power button.
Damaged Battery
If the battery is damaged, you will need to replace it. To replace the battery, follow this repair guide.
After replacing the battery, let the device charge over night, then power the device on.
Glass Screen Damaged
The screen of the device is scratched or cracked.
Cracked Screen
If the screen is cracked, you may want to replace it. To replace the screen, follow this repair guide.
Allison Poh
crwdns2935283:010/20/15crwdne2935283:0
549 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 crwdns2935289:0UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015crwdne2935289:0
UMASSD-GULBRANDSEN-F15S5G1
My tf700 says it is connected to my home Wi-Fi but anytime I try to use the internet it says error and that it can’t get a secure connection.
Noah Whitehead - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2959996:0crwdne2959996:0 1,560
