The screen is cracked
Oh no! An accidental bump has left your watch with broken or shattered glass.
Broken cover glass
Take a deep breath and see if your Apple Watch will turn on and operate normally. In most cases, it is still functional but now a cosmetic disaster. Unfortunately, the Apple Watch screen glass and display are fused together and must be replaced as one piece.
You can [[ crwdns2944616:0crwdne2944616:0 ]].
Instructions for replacing the screen can be found here.
The Apple Watch is frozen or unresponsive
Even after furious button mashing and screen smashing, your watch doesn't respond.
Restart the Apple Watch
Sometimes all it takes is a restart for the watch to become responsive again. To restart your watch when it is unresponsive, press and hold the side button down until the Apple logo appears (~10 seconds).
Force-restart the Apple Watch
If a normal restart doesn’t do the job, don’t despair. To force-restart your watch when it is unresponsive, press and hold the side button and the digital crown until the Apple logo appears (~10 seconds).
Apple Watch will not charge (snake screen or red lightning bolt)
Placing your Apple Watch on the charger does not bring it to life.
Bad cable connection
Check the charging cable for damage and dirt (including on the charging pad). Try plugging your watch’s charge cable into a wall outlet, rather than your laptop’s USB port, as this will provide greater power input.
Broken charger or USB cord
Try using different cables, chargers and wall outlets to make sure none of them has a malfunction.
Be patient
Leave the watch on the charger for at least one hour to see if the watch begins to charge. With a completely depleted battery, it might take some time before the watch comes to life again.
Restart the watch
If the watch still isn’t responding as expected, try to restart it or even force-restart it (see above for instructions).
Let the battery die
As a last resort, you can let the battery run down until the watch completely shuts off on its own, and then leave it off for another day for the battery to deplete completely (yeah, it’s difficult—a whole day without your Apple Watch). Then try charging it again the next day.
Apple Watch will not turn on
You cannot get your beloved Apple Watch to turn on.
Drained/dead battery/bad charger
Place your watch onto the charger and connect it to your computer or wall outlet to charge. If the watch does not charge when placed on the charger, it likely has a dead battery or a bad charger. Check the steps above in “Apple Watch will not charge” first. Try replacing the battery with a partially charged one and see if the watch will turn on. If the watch does turn on or the charging indicator comes on, then the old battery was the problem. If the watch won’t turn on or show any charging indication, there may be a side button or logic board issue.
Bad side button
If the side button doesn't seem to work, place the watch onto the charger and connect it to a wall outlet or a computer and let it charge. If the watch turns on and has power, then there might be a problem with the side button.
Bad display
It’s possible that the watch appears turned off because the display is bad. If the Apple Watch sounds like it’s working properly but nothing is visible, it’s possible the display is faulty and must be replaced. An easy way to test this is to ping the watch from your iPhone and wait for a sound or vibration. If it vibrates or you hear a sound but nothing displays on the screen, then the screen is most likely the problem. Try replacing it.
NFC nonfunctional after replacement (Series 2 and later)
Following a screen replacement, ApplePay or NFC features stop working.
The NFC chip is linked to the watch
As a security feature, the NFC chip is linked to your watch during setup. If the original screen is replaced, damaged, or disconnected, NFC features will cease to function.
Make sure to deactivate any NFC-related functions and delete all your Apple Pay account info before replacing the screen. If necessary, put the old screen back on, turn on the watch, and remove your Apple Pay settings via your iPhone. Then go ahead and replace the screen with the new one, and set up Apple Pay again.
crwdns2944067:012crwdne2944067:0
Series 3 LTE 42mm suddenly stopped working, and was getting hot to the touch on the charger. It’s been unresponsive. It worked flawlessly before this happened, and there is no physical damage. Any thoughts? Could it be a bad battery? Apple was of no help, since it’s out of warranty. They just suggested sending it in, with a cost to replace that’s almost as expensive as buying another one.
redgeminipa - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Same problem here! Series 3 LTE 42mm (Nike) worked fine. One day the battery was probably running low, and next time on the charging pod it would not charge, flash/flicker with the logo and get reasonably warm. Tried charging again and again to no avail. Apple Store says „sorry, buy a new watch – we will not even replace the battery“.
While originally I was okay to spend the money for battery replacement at the store, I now think about doing the replacement by myself.
Thorsten Wollweber - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Mine is doing the same thing did you figure out what to do I have Nike s5
Holly Kane - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I've got the same problem. It's hot to touch while charging and nothing happens. Nothing.
Kent Miller - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
got a s2 watch that gets real hot when charging, and doesn't seem to work. it worked years ago but then it got abandoned. we found it and it won't charge. it has an aluminum case if that helps.
billy bob - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
