crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Speaker Will Not Pair With Device
No matter what I try I can't pair my device with the speaker.
Speaker Is Not Turned On
The speaker turns off automatically if it is not paired in 5 minutes. Turn the speaker off, then back on to re-enter pairing mode. A tone sounds and the LED blinks quickly. If your speaker does not enter pairing mode, press and hold the function (center button on the top of the device) for 1 to 3 seconds to put your speaker in pairing mode.
Device Is Out of Range
Your AmazonBasics BTV1 has a range of 30 feet (9.1m), make sure you are within this range.
Device Does Not Support Bluetooth 4.0
Make sure your device is Bluetooth 4.0 compatible.
Speaker Will Not Turn On
When I try to turn my speaker on, nothing happens.
Device Needs to be Charged
To charge the speaker, connect the USB charging cable to the charging port and an available USB port.
Charging Cable Defective
Your charge cable may be defective, try using a different charge cord.
Battery Is Defective
If none of the above solve your issue, your battery might be defective. Refer to the AmazonBasics BTV1 Battery Replacement guide.
Poor Sound Quality
When playing my music, crackling noises come through the speakers.
Aux Cord Not Fully Connected
If you are using an aux cable to connect your device, make sure the cable is fully plugged into the speakers and there is no debris in the aux port.
If you are connecting with bluetooth, make sure you are within the device's range, 30 feet (9.1m).
Speakers Damaged
If you've tried all of the above, your speakers might be damaged. Check out our AmazonBasics BTV1 Speaker Replacement guide.
Buttons Do Not Work
I can't change the volume on my speaker.
Restricted Functions
If the device is connected to the AUX-in jack, you're going to have to use your device to control the volume.
Sticky Buttons
Use slightly dampened toothbrush or cotton swab to gently clean buttons. Make sure that the toothbrush or swab is not dripping with water. Wipe down area with a dry cloth after you have cleaned it.
Microphone Does Not Work
When I speak into the microphone it doesn't pick up my voice.
Microphone Facing Wrong Direction
Make sure your speaker is powered on, then turn the speaker so that the LED light on the top is on the side closest to you.
Chris Shannon
crwdns2935283:002/01/16crwdne2935283:0
1,039 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 14-2, Lacy Spring 2016 crwdns2935289:0USF Tampa, Team 14-2, Lacy Spring 2016crwdne2935289:0
USFT-LACY-S16S14G2
crwdns2944067:016crwdne2944067:0
My speaker, which worked fine for 4 months, will no longer pair with my phone. I tried the troubleshooting to no avail.
Jill Jordan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
me too it worked until i had to remove the device for another device now i can not get it to pair up
episcoluth - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My speaker, which paired fine and worked perfectly for 4 months, no longer works. Tried the off/on 3 second thing to no avail.
My speaker has worked fine for one year but now when i turn it on, the sound no longer will come out of my speaker
Irene Bowser - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Same thing, my speaker won't pair anymore. The button is blue but it won't show up as an available peer for pairing…. Have anyone has succeed in pairing?
Jaime Blanco - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 26,146
