crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Tablet won't turn on
''Your tablet won't respond or show any sign of powering up."
Faulty Power Adapter
Check and make sure the power adapter is plugged in. If it is, make sure the battery picture comes on the screen. If picture doesn't show up on the screen, and the adapter is plugged in, adapter is faulty. Consider purchasing a replacement adapter.
Faulty battery
If your tablet won't turn on, and your adapter works on other devices, but not the Acer tablet, that is a sign of faulty battery, and your battery needs to be replaced.
Acer Iconia One 7 Battery Replacement
Broken power switch
A possible reason your tablet is not powering up could be a broken power switch.
Make sure it is properly in place. If the button is missing, then you may need a replacement.
Acer Iconia A110 On/Off Switch Replacement
Bad display
If the battery is in check, It is possible that the display is bad or broken, and must be replaced. If your display seems to be frozen, refer to the section below on a frozen screen.
Acer Iconia One 7 Front Facing Camera Replacement
Bad motherboard
If neither of the listed problems is the issue, the mother board itself may be bad. First check all of the wires and connections from the display to the logic board. If they are all connected properly, but the tablet still does not respond, then you may need to replace the mother board.
Acer Iconia One 7 Motherboard Replacement
Frozen Display
"Tablet does not respond to touch; display remains the same."
Battery life is low
It is possible your tablet will not respond if the battery is too low. Plug it in and charge it.
Tablet requires a restart
Sometimes your tablet needs a restart to get it to function. Reboot your tablet by holding the power button for 30 seconds.
Internal memory is not enough
If you have installed large in size applications may make the tablet hang or stuck or frozen or bricks or not responsive for the touch screen. First step is try to uninstall the applications and perform soft reset or reboot your tablet.
If your system is still frozen, you may try using the hardware reset pinhole on your tablet, to see if it will allow your system to boot.
Please follow the hard reset instructions.
1) Press and hold the power button and volume + button until it vibrates
2) Release the power button and unlock the screen lock switch at the side of the device.
3) The device has been restored to factory settings.
Short battery life
"The tablet's battery performance life is way below the advertised average of 8 hours."
Running more applications than the tablet is intended to handle
Running too many applications simultaneously, causing the battery to consume more power and drain faster. The more frequent usage weakens the battery over a shorter period of time.
Dead battery
The cause could be that the battery is dead. Plug it into the adapter and make sure it charges. If it does not charge, and you can use the table only while plugged in, then it may be a bad battery.
Acer Iconia A110 Battery Replacement
Malfunctioning battery
Battery may be faulty. If all else fails, the battery is in need of replacement.
Unresponsive buttons
"The buttons just won't work no matter how many times you press them."
Missing buttons
If the buttons are obviously missing, then they will need to be replaced.
Acer Iconia Tab A500 Power Button/Motherboard Replacement
Bad connection
Wiring could be disrupted. First make sure the buttons are in place, then check the wiring. If that's the case right after reassembling your device, make sure you look at the guide you used and follow the steps one more time, to look for a possible misplacement.
Jammed buttons
It could be that the buttons are jammed. In this case, try pressing the buttons repeatedly in order to unstick them, or make sure they are in the right location. If this does not work, replace the unresponsive buttons.
Unresponsive Camera
"Camera button is unresponsive on my screen no matter how many times I try to reboot my tablet."
If your camera isn't working at all but it's not damaged, contact your local Acer service support or download a new camera application from Google Play.
Camera lens damaged or not in place
In this case camera application is not functioning. Camera lens needs to be put in the right location or simply replaced.
Acer Iconia One 7 Rear-Facing Camera Replacement
pavlinacamp
crwdns2935283:009/01/15crwdne2935283:0
79 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
USF Tampa, Team 8-5, Eyestone Fall 2015 crwdns2935289:0USF Tampa, Team 8-5, Eyestone Fall 2015crwdne2935289:0
USFT-EYESTONE-F15S8G5
crwdns2944067:013crwdne2944067:0
Does not address black screen with power
Clyde Waldo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Does not adress black screen with power
my tablet will not connect to server to install apps
REGINA JOHNSON - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
need info on server connection repairs
crwdns2936753:030crwdne2936753:0 68
crwdns2959996:0crwdne2959996:0 34,230
