RadioShack Heat Gun 120V 60Hz 300W with reflector Teardown
crwdns2936025:05crwdne2936025:0 —
The primary assembly has a metal tube which directed the hot air out of the nozzle. The tube enclosed a heating element spiraled around a framework insulated by a heat resistant paper. The heating element is essentially a resistor wound around a synthetic thread that resisted burning.
The other element of the assembly was a brushless DC motor. The input AC voltage is put through a 4-diode full bridge rectifier with a smoothing capacitor before the DC voltage is fed into the motor and the resistor. The DC motor is attached to a plastic fan which drives the air through vent holesand down the metal tube across the heating elements
