Nokia AC-16U USB Power Adapter Teardown
crwdns2936025:01crwdne2936025:0 —
This power supply is slim and unusually attractive.
That white case is 39mm in diameter, and 15mm thick: pretty small for this power level (see heat sinks later).
The case is glued together, so you're not going to get into this one cleanly. I sawed a slot in the side, and used a screwdriver to crack the glue.
