Samsung Galaxy Note 4 Teardown
crwdns2936025:08crwdne2936025:0 —
Cut the adhesive between LCD screen and mid plate carefully. Especially care about the position of the flex very much.
The adhesive is in the red scale, it's strong and we had damaged the foil film on the back of the screen when cut the adhesive. Heat with a low degree will make easier.
Release the connectors from motherboard. The right one is S Pen sensor film connector and the left one is LCD screen connector.
You also can see the soft keys on the bottom side. So be careful when cut the adhesive, don't hurt that part.
At last, remove LCD screen assembly carefully.
