Motorola Moto 360 Teardown
crwdns2936025:022crwdne2936025:0 —
Motorola Moto 360 Repairability Score: 3 out of 10 (10 is easiest to repair).
Watch band is a standard size and easily replaceable (with small enough tweezers).
Heat and careful prying is required to remove the rear panel—and then even more prying to pull out the inner housing. It is very difficult to open the device without compromising its waterproof seals.
The battery is trapped deep within the device, within the inner housing. Nearly complete disassembly is required to replace.
The display does require complete disassembly to replace, as it is removed from the back of the main bezel.
