HP G62-453 Teardown
crwdns2936025:015crwdne2936025:0 —
now remove the usb conncetor + the dc jack connector.
you can remove the dc jack (head) by pulling it out (sliding). if it's loose, then you can remove the connector from the motherboard.
if you remove the usb connector, be careful because the cable is taped to the case. pull gently
