BlackBerry Bold 9700 Teardown
crwdns2936025:012crwdne2936025:0 —
Just once piece left to remove, the media card slot. Gently lift the ribbon cable up, and pry the small metal piece up from the lower case using your fingernails.
Take care not to put any stress on the tiny and fragile ribbon cable! It will break easily. It is not necessary to peel this cable up from the metal piece below, as they will come up together, and you can't take the ribbon cable off anyways.
Slide the slot up and out of the lower case. That's it!!
