Samson Meteor Teardown
crwdns2936025:02crwdne2936025:0 —
After removing the screws, the capsule housing should be able to be removed. Remove it slowly there are still wires attached coming from the microphone capsule and a ground wire.
To separate the housing, Remove the 4 screws highlighted in blue to allow you to remove a cover and then allow you to separate the housing and the capsule in its shock mount as shown in image 2
