LG Chromebase 22" Teardown
crwdns2936025:05crwdne2936025:0 —
Detach the webcam cable using a spudger. You will probably break the clip, but it will still reconnect. Next, remove the Wi-Fi card by removing the screw and lifting it out. This is required to remove the motherboard in the next step.
You do not need to detach the Wi-Fi antennas or other cables. Just remove the tape and slide them out of the way.
Leave the video board attached to the motherboard frame. You should be able to raise the entire frame without detaching the control cable from the video board.
