Xbox One Elite Wireless Controller Series 2 Teardown
crwdns2936025:07crwdne2936025:0 —
Now, for the serious stuff—There are four solder points on the left and right that can be de-soldered depending on what is required during a repair. The temperature required to remove is approx 450 degrees C.
If you arent removing the solder be careful while removing the motherboard in this step.
Remove the 2 T6 Torx screws (yellow circle) and gently slide the motherboard up along the two dowel pins (red circle). The motherboard (green) can now be repositioned away from the daughterboard(blue).
The black and grey wires are looped through the plastic tabs on either end as well as around the front of the plastic panel (yellow circle), removing them from here can allow more free room without de-soldering.
The headphone jack can now also be removed (red square)
