Kambrook Blitz 2 Go Teardown
crwdns2936025:02crwdne2936025:0 —
The bottom of this blender has four rubber bases to help prevent slipping and stabilize the device when it is stationary and working. These four rubber bases can be easily pulled out with your fingers.
There are two phillips screws inside the round hole. Use a Phillips screwdriver to remove them
There are two special screws in the two round holes. If forced disassembly is allowed, the base can be opened by using an electric drill to destroy the two screws.
Length of rubber sole: 40mm
Width of rubber sole: 7mm, Weight: 4.8g
SS Philips screw diameter: 5.2mm
SS Philips screw length: 10mm, Weight: <1 g
Rubber is made by liquefying rubber and injecting it into a mold of a specific shape and cooling it. The manufacturing process of stainless steel screws is divided into four steps: cold heading, heat treatment, turning and grinding.
