Philips HX8210/22 Sonicare Airfloss Microjet Teardown
crwdns2936025:02crwdne2936025:0 —
Gently unplug the main board from the mechanical parts, pulling it up from the bottom (it is not glued)
Remove the tape holding the cables
Unplug the water cable
You can now pull out all the components, you willl have only four cables going to the upper part (for the battery and the trigger button)
