Kogan RGB Mechanical Keyboard Teardown
crwdns2936025:021crwdne2936025:0 —
The housing assembly protects and holds together other key spring components. The lower white component locates the circuit pins and spring to the correct positions. The upper clear component clips onto the white lower housing and secures the keycap connector.
Both components are injection moulded however to achieve the clear finish the upper component is manufactured from acrylic whereas the lower opaque component is ABS.
Upper component | Dimensions: 13x15x10 mm
Lower component | Dimensions: 13x15x13
