2 Slice Anko Toaster Teardown
crwdns2936025:03crwdne2936025:0 —
Now that most of the toaster's components are revealed we will start with removing the control panels. The control panels or PCB's are located in the upper shell of the toaster where you would usualy push your toast down. These PCB's are simply screwed in with screws. So unscew them and pull them out.
Now the top frame can be fully seperated from the bottom frame.
