SEIKI stick mixer Teardown
crwdns2936025:09crwdne2936025:0 —
Because the plastic shell and the metal protection part is directly fixed together, pry open the four fixed parts can not be disassembled, and for the time being there is no existing tool to further dismantle it, so the use of pictures labelled.
Use an electric drill to drill through the part of the plastic shell that connects to the internal blade.
Seen inside by the opening is a blade with a long handle that is separate from the outer metal protective case.
The metal blade passes from the bottom of the blender section to the top and is secured inside the protective metal casing by the clasp marked by the red circle.
