Sonicare Toothbrush HX6930 Teardown
crwdns2936025:02crwdne2936025:0 —
Remove rubber ckt board cover & pull off the white cap at far left. Then unsolder wires at 6 points shown. While applying heat, extract solder with solder pump & solder wick. Gradually pry ckt board off the soldered points while applying heat. Then pull out the battery from the other side.
