Nokia Asha 200 Teardown
crwdns2936025:02crwdne2936025:0 —
Insert spudger between the front/back case and lever untill you hear a click.
Slowly work your way around until the bottom end is separated. Then with the bottom end facing your body, try to pull the back case towards yourself.
Make sure not to loose Sim2 and Micro SD covers as they easily fall out. Also when re-assembling make sure they are pulled out otherwise you will have trouble putting things back together
