Amazon Echo Dot 3rd Generation Teardown
crwdns2936025:01crwdne2936025:0 —
To loosen the adhesive holding the cover onto the bottom of the Echo Dot, heat up the bottom of the Echo Dot using a hairdryer at the lowest heat setting for approximately 10-20 seconds until the bottom feels warm to the touch and the cover is easier to pry off. Do not use excessive heat. If you do not have a heat source, go to the next step.
