Bread Maker Teardown
crwdns2936025:01crwdne2936025:0 —
The Toast Select Luxe adjusts the toasting time for each type of bread. 'Lift & Look' to check if it's done. Press 'A Bit More' and to give it just that… a little bit more. Follow toasting progress with the LED countdown indicator. Crafted with brushed stainless steel in premium metallic finishes and chrome accents.
VARIABLE BROWNING CONTROL Toast to your ideal browness level while the LED indicates your browning progress.
INNOVATIVE AUTO FEATURES 1-Touch 'A Bit More' and 'Lift & Look' functions are derived directly from your feedback and makes for flawless toasting.
EASY CLEANING No need to ever lift when cleaning. Just pull out the front crumb tray and tip it into the dustbin.
Construction Materials:Brushed stainless steel body with back-lit buttons.
Dimensions (WxDxH):8.2" x 7.9" x 13.4"
Power:1000 Watts Voltage:120Volts, 60Hz Settings:6 Bread Settings: Wholewheat, White, Bagel, Waffles, Pastries and English Muffins 4 Functions: 'Lift & Look', 'A Bit More'/Reheat, Frozen and Cancel
