Breville Toaster Teardown
crwdns2936025:03crwdne2936025:0 —
Once removing the screws, partially seperate the body from the white casing.
As shown, there are 4 screws that have to be removed to fully seperate the 2 parts.
Use a phillips screwdriver to unscrew the screws.
Flip the toaster on the other side and pull the highlighted wire to detach it from the bottom part.
You can now seperate the parts to give 2 seperate parts. (The white casing and the electrical body).
