Hyperkin Duke Teardown
crwdns2936025:010crwdne2936025:0 —
Remove the two screws securing the assembly to the PCB riser
The D-Pad assembly makes electrical connectivity to the main PCB via the orange highlighted connector. To remove, pull D-Pad assembly away from main PCB
The conductive rubber has been press fitted to the PCB
To remove, very gently, as close as possible to the protruding rubber nipple, pull the conductive rubber piece away from the PCB
