Intertek Clip Fan 0610 Teardown
crwdns2936025:08crwdne2936025:0 —
Next, locate the two Phillips #2 screws which fasten the switch to the back plate (circled in red).
Unscrew using a Phillips #2 screwdriver and store the screws in a safe location.
Pull the switch away from the back plate. Once the backplate is removed, maintenance and cleaning can take place.
Note: when reassembling the switch to the back plate, ensure that the switch is facing the right direction in order to match the High and Low speed back plate markings with the actual High and Low speeds of the switch.
