Fairphone 3 Teardown
crwdns2936025:04crwdne2936025:0 —
Removing the battery is also easy as Android 9—it lifts right out using the notch at the bottom.
With its recessed contacts and sturdier plastic casing, this battery is a well-protected throwback we're happy to see.
At 11.781 Wh (3,060 mAh at 3.85 V), this juice box is not the biggest around these days. But it should get you through the day—and if it doesn't, you can just carry a spare and swap it out!
It beats the Google Pixel 3a in capacity (11.55 Wh) but cannot quite touch the iPhone Xs Max (12.08 Wh), let alone the Shift 6m (16.3 Wh).
The underside of the battery bears an encouraging message: "Well done. You're what progress looks like." Speaking of which, it's time to make some more teardown progress. Onward!
