Seagate Backup Plus Hub Teardown
crwdns2936025:013crwdne2936025:0 —
If you want to store the bay once the drive is out, you can set the rubber feet with the screws inside inside of where they would be if the drive was there, then slide it into the wider part of the case such that the case matches up with the board. then press the other part of the plastic case together with it to snap it back together.
If this is confusing, go back a few steps and try to reverse how it was disassembled.
This was my first iFixit guide so be sure to tell me how I did!
With that, I hope you all are happy with how this guide turned out!
