TI-84 Plus CE Teardown
crwdns2936025:05crwdne2936025:0 —
Gently bend back the Aluminum shield. You will not be able to take all of it off since it is partially glued on.
There is some shielding wrapped around the LCD.
If you need to access the LCD, you can pick it up and bend it back.
Be careful not to rip the tan ribbon cable. (Which is removable)
Follow this guide to safely disconnect the ribbon cable from the ZIF connector: Recognizing & Disconnecting Cable Connectors
With the LCD out, you can now easily pop out the transparent, plastic cover that's connected to the shell. This allows you to replace the glue if it's weak.
