crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Texas Instruments TI-82crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Texas Instruments TI-82 Teardown, Texas Instruments TI-82 Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The calculator comes with a matching protective shield which slides down over the front; when the calculator is in use, you can slide it over the back. This is a nice touch, as it makes the cover much more difficult to lose.
  2. Texas Instruments TI-82 Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Texas Instruments TI-82 Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Texas Instruments TI-82 Teardown: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device over to access the battery cover.
    • Using a spudger, pry the release tab down and then pull the battery door up and off the calculator.
    • Remove:
    • 2 7.2mm Phillips #0 screws
    • 1 15.3mm Phillips #0 screw, and a battery retaining clip.
    • The CR1616 coin cell battery preserves settings and programs in memory while the main batteries are being changed.
  3. Texas Instruments TI-82 Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a spudger into the seam between the two halves of the case, and pry it apart.
    • Watch out for corrosion in older calculators around the battery terminals -- this is why you should never leave batteries in electronics for extended periods of time.
  4. Texas Instruments TI-82 Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Opening the two halves of the calculator reveals a foil shield over the rest of the electronics.
    • Remove four Phillips screws to access the electronics underneath, then pull the shield away.
  5. Texas Instruments TI-82 Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • ... And, here's the guts of the thing.
    • SRM20255LLM10 / F4ZM1938 (32Kbyte SRAM)
    • LH531GP4 (Mask ROM)
    • T 84C00AM-8 (Z80 CPU)
    • Toshiba / TC14L010AF / 1273 9506EAI (ASIC)
  6. Texas Instruments TI-82 Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Texas Instruments TI-82 Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the remaining Phillips screws.
    • The screen and main board will lift out, leaving the membrane keypad in the front case.
    Thank You for the description. I found a little difference to mine calculator: I have one screw more see (where the red arrow is)
    https://ibb.co/MMwp1W3
    Thomas Buschhardt - crwdns2934203:0crwdne2934203:0
bushing
crwdns2935283:004/23/10crwdne2935283:0
10 412 crwdns2915208:0crwdne2915208:0
crwdns2935297:013crwdne2935297:0
Minor correction, the RAM part is SRM20256LLM10, a CMOS 256 kilobit (32x8) 100ns static RAM in 28 pin SOP form factor.
Nick M - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 21,752
